Exploring public NHANES data using Rcupcake
The Rcupcake package contains functions to query different databases through the BD2K RESTful API. BD2K RESTful API is an interface that provides access to different data sources, making easier data accessibility, analysis reproducibility and scalability.
The package is installed via devtools using it’s GitHub URL (hms-dbmi/Rcupcake)
library( Rcupcake )
Rcupcake package follows a four-step process to retrieve the data from a database:
  1. Start session
  2. Select the variables of interest
  3. Build the JSON query
  4. Run the query to obtain the data
The start.session function establishes a connection to the database of interest and it requires two arguments:
  • url: the url of the database of interest.
  • apiKey: the key to successfully access to the data.
It works as follows
sessionEx <- start.session(
    url    = "url",
    apiKey = "key"
In this case, the URL corresponds to https://nhanes.hms.harvard.edu/.
## [1] "Start Session: success"
With the connection opened we can proceed to explores the existing variables. To this end we use get.children.
nhanesCategories <- get.children(
   url       = "https://nhanes.hms.harvard.edu/",
   fieldname = "/nhanes/Demo"
nhanesCategories
## [1] "/nhanes/Demo/demographics/demographics/"
## [2] "/nhanes/Demo/examination/examination/"
## [3] "/nhanes/Demo/laboratory/laboratory/"
## [4] "/nhanes/Demo/questionnaire/questionnaire/"
As you can see, the content of the fieldname it not really clear since it includes a Demo and the results includes two times the category. Let’s hope the Rcupcake’s paper puts some light here.
Using the same strategy we can obtain the list of laboratory tests:
nhanesLaboratory <- get.children(
   fieldname = "/nhanes/Demo/laboratory/laboratory/"
nhanesLaboratory
##  [1] "/nhanes/Demo/laboratory/laboratory/acrylamide/"
##  [2] "/nhanes/Demo/laboratory/laboratory/aging/"
##  [3] "/nhanes/Demo/laboratory/laboratory/allergen test/"
##  [4] "/nhanes/Demo/laboratory/laboratory/bacterial infection/"
##  [5] "/nhanes/Demo/laboratory/laboratory/biochemistry/"
##  [6] "/nhanes/Demo/laboratory/laboratory/blood/"
##  [7] "/nhanes/Demo/laboratory/laboratory/cotinine/"
##  [8] "/nhanes/Demo/laboratory/laboratory/diakyl/"
##  [9] "/nhanes/Demo/laboratory/laboratory/dioxins/"
## [10] "/nhanes/Demo/laboratory/laboratory/furans/"
## [11] "/nhanes/Demo/laboratory/laboratory/heavy metals/"
## [12] "/nhanes/Demo/laboratory/laboratory/hormone/"
## [13] "/nhanes/Demo/laboratory/laboratory/hydrocarbons/"
## [14] "/nhanes/Demo/laboratory/laboratory/melamine/"
## [15] "/nhanes/Demo/laboratory/laboratory/nutrients/"
## [16] "/nhanes/Demo/laboratory/laboratory/pcbs/"
## [17] "/nhanes/Demo/laboratory/laboratory/perchlorate/"
## [18] "/nhanes/Demo/laboratory/laboratory/pesticides/"
## [19] "/nhanes/Demo/laboratory/laboratory/phenols/"
## [20] "/nhanes/Demo/laboratory/laboratory/phthalates/"
## [21] "/nhanes/Demo/laboratory/laboratory/phytoestrogens/"
## [22] "/nhanes/Demo/laboratory/laboratory/polybrominated ethers/"
## [23] "/nhanes/Demo/laboratory/laboratory/polyflourochemicals/"
## [24] "/nhanes/Demo/laboratory/laboratory/viral infection/"
## [25] "/nhanes/Demo/laboratory/laboratory/volatile compounds/"
Or the demographic information:
nhanesDemographic <- get.children(
   fieldname = "/nhanes/Demo/demographics/demographics/"
nhanesDemographic
##  [1] "/nhanes/Demo/demographics/demographics/AGE/"
##  [2] "/nhanes/Demo/demographics/demographics/area/"
##  [3] "/nhanes/Demo/demographics/demographics/DMDBORN/"
##  [4] "/nhanes/Demo/demographics/demographics/DMDMARTL/"
##  [5] "/nhanes/Demo/demographics/demographics/education/"
##  [6] "/nhanes/Demo/demographics/demographics/INDFMPIR/"
##  [7] "/nhanes/Demo/demographics/demographics/RACE/"
##  [8] "/nhanes/Demo/demographics/demographics/SDDSRVYR/"
##  [9] "/nhanes/Demo/demographics/demographics/SDMVPSU/"
## [10] "/nhanes/Demo/demographics/demographics/SDMVSTRA/"
## [11] "/nhanes/Demo/demographics/demographics/SES_LEVEL/"
## [12] "/nhanes/Demo/demographics/demographics/SEX/"
## [13] "/nhanes/Demo/demographics/demographics/WTMEC2YR/"
## [14] "/nhanes/Demo/demographics/demographics/WTMEC4YR/"
nhanesExamination <- get.children(
   fieldname = "/nhanes/Demo/examination/examination/"
nhanesExamination
## [1] "/nhanes/Demo/examination/examination/blood pressure/"
## [2] "/nhanes/Demo/examination/examination/body measures/"
## [3] "/nhanes/Demo/examination/examination/physical fitness/"
Once we now the paths of the variables we want to use we put them in a vector.
nhanesPressure <- get.children(
    fieldname = "/nhanes/Demo/examination/examination/blood pressure/"
nhanesMetals <- get.children(
    fieldname = "/nhanes/Demo/laboratory/laboratory/heavy metals/"
nhanesVector <- c(
    nhanesDemographic,
    nhanesPressure,
    nhanesMetals
This vector indicates to my.query where to locate the fields we want to retrieve to from the database. The field must be indicated into myfields, separated using the vertical columns character (|).
At this point we need to now that the first field filters the output by existing value. This means that the samples with missing data in the first field will be dropped by default.
query <- my.query(
    myfields = "AGE|SEX|mean diastolic|Mercury, hair (ppm)|Lead (ug per dL)",
    myvector = nhanesVector,
The function returns the JSON structure of the query:
query
##   "select": [
##       "field": {
##         "pui": "/nhanes/Demo/demographics/demographics/AGE/",
##         "dataType": "string"
##       "alias": "/nhanes/Demo/demographics/demographics/AGE/"
##       "field": {
##         "pui": "/nhanes/Demo/demographics/demographics/SEX/female/",
##       "alias": "/nhanes/Demo/demographics/demographics/SEX/"
##       "field": {
##         "pui": "/nhanes/Demo/demographics/demographics/SEX/male/",
##       "field": {
##         "pui": "/nhanes/Demo/examination/examination/blood pressure/mean diastolic/",
##       "alias": "/nhanes/Demo/examination/examination/blood pressure/mean diastolic/"
##   "where": [
##       "field": {
##         "dataType": "STRING"
##       "predicate": "CONTAINS",
##       "fields": {
##         "ENOUNTER": "NO"
The last step is to retrieve the data. Thai is done with my.data, it retrieves he data as a data.frame and save it into a file.
data <- my.data(
    query          = query,
    responseFormat = "CSV",
    outputPath     = "~/dataNHANES.txt"
The variabte data can be explored as standard data.frame:
dim( data )
## [1] 41474     4
colnames( data )
## [1] "patient_id"
## [2] "X.nhanes.Demo.demographics.demographics.SEX."
## [3] "X.nhanes.Demo.examination.examination.blood.pressure.mean.diastolic."
## [4] "X.nhanes.Demo.demographics.demographics.AGE."
# Gender Proportion
prop.table( table( data[ , 2] ) )
##    female      male
## 0.5114047 0.4885953
# Range of age
summary( data[ , 4] )
##    Min. 1st Qu.  Median    Mean 3rd Qu.    Max.
##    0.00   10.00   19.00   29.25   47.00   85.00
# Range of Blood Diastolic Mean
summary( data[ , 3 ] )
##    Min. 1st Qu.  Median    Mean 3rd Qu.    Max.    NA's
##    0.00   57.33   65.33   64.98   73.33  132.00   15438
